| • | To create a reference layer |
| • | To modify a reference layer |
| • | To commit a reference layer |
You can create a reference layer by basing it on an existing layer or by placing an image. For more information, see Opening and placing files.
| 1 | Select a layer. |
| 2 | Choose Layers |
| The layer’s icon in the Layers panel changes to an eight-handled shape |
| • | Select a reference layer. |
Drag a corner handle. If you want to maintain the layer proportions, hold down Shift as you drag. The pointer changes when you position it over a corner handle
Hold down Command (Mac OS) or Ctrl (Windows), and drag a corner handle. The pointer changes when you position it over a corner handle
Hold down Command (Mac OS) or Ctrl (Windows), and drag a side handle. The pointer changes when you position it over a side handle
| • | In the Layers panel, right-click a reference layer, and click Convert To Default Layer. |
| The conversion process might take a few seconds, depending on the size and quality of the layer. |
