• | To add frames |
• | To delete frames |
• | To erase frames |
You can add frames at the end or beginning of a movie, or in between any frames in the stack. You can also delete frames from a movie and all subsequent frames are renumbered as necessary. In addition, you can clear the frame contents, but retain the paper color. You cannot undo the actions of deleting and erasing frames, so it’s best to create animations in small segments and then combine them when you are finished. For more information, see Inserting movies.
To add frames |
1 . | Choose Movie ![]() |
2 . | In the Add Frames dialog box, type the number of frames in the Add box. |
3 . | Enable an option for frame placement. |
For example, to add six blank frames before frame 10, type 6 in the Add box, enable the Before option, and type 10 in the Frame box. |
To delete frames |
2 . | In the Delete Frames dialog box, enter the range of frames to delete. |
To erase frames |
2 . | In the Erase Frames dialog box, enter the range of frames to erase. |
