Corel Painter Help :
Adding text : Adding drop shadows to text
You can apply a drop shadow to text. You can choose between two drop shadow styles: external, which places the shadow behind the text, or internal, which places the shadow inside the text.
You can also change the composite method for text or the drop shadow of text. For more information, see Blending layers by using composite methods.
2 . |
In the Layers panel, select a text layer. |
External Shadow — makes your letters look as though they’re casting a shadow onto a sheet of paper held beneath them |
Internal Shadow — makes your letters look like cutouts held above a sheet of paper that is the same color as the text |
You can also add a shadow by clicking the Show or hide the Text panel button
on the property bar, and choosing one of the shadow buttons in the Text panel.
