Corel Painter Help :
Layers : Changing layer order
The layer order determines how the layers in a document interact. When you create a new pixel-based layer, it appears on top of the canvas (when the canvas is selected) or on top of the selected layer. New Watercolor, Liquid Ink, and dynamic layers are always created on top of existing layers. Depending on its transparency, masking, and compositing characteristics, the layer will obscure or otherwise affect the underlying layers.
A document’s layer order is reflected in the Layers panel. The bottom layer is always the canvas.
In this example, the picture of the brush is contained in a layer. The brush layer is displayed in the top position (left) and in the bottom position (right).
1 . |
Choose the Layer Adjuster tool from the toolbox. |
2 . |
In the Layers panel, drag a layer to a new position. |
When you have nonoverlapping layers in a document, the Move Up One Layer and Move Down One Layer commands may move the selected layer past multiple layers. This is because nonoverlapping layers are considered to be at the same level. The Move Up One Layer and Move Down One Layer commands move the selected layer (or layers) above or below the next level. To move a layer to a position between nonoverlapping layers, drag it in the Layers panel.
