Corel Painter Help :
Adding text : Converting text layers
You can convert a text layer into a standard layer so that you can apply effects such as gradations, blends, or surface textures. For example, you can also apply surface control textures to give the text a three-dimensional appearance. For more information, see Adjusting light properties.
You can also convert a text layer to shapes, which allows you to move and edit individual characters. For more information, see Shapes.
1 . |
In the Layers panel, choose a text layer. |
![*](images/note.svg)
If the text has an outside or an inside shadow, then two layers — one for the text and one for the shadow — are created within a group.
1 . |
Text shadows and blurring effects are not converted when you use this command.
