Corel Painter terms
Before you get started with Corel Painter, you should be familiar with the following terms.
Image sampling lets you copy part of one image and reuse it elsewhere in the image or in another image. You can sample an image by using the Rubber Stamp tool, a Cloner brush that supports offset sampling, or a Cloner brush that supports multi-point sampling. Sampling is similar to cloning, but, unlike cloning, it does not create a separate document that stores clone sources.
