Corel Painter offers various methods for making pixel-based selections. The Magic Wand tool selects groups of pixels according to color. You can adjust the settings to control the range of colors, and you can also choose to include only adjacent colors (contiguous) or only nonadjacent colors (noncontiguous).
You can move pixel-based selections, but you cannot resize or rotate them. To apply transformations to pixel-based selections, convert any pixel-based selections into path-based selections. For more information, see To convert a pixel-based selection to a path-based selection.
To select an area by using the Magic Wand tool |
1 . | In the toolbox, click the Magic Wand tool |
2 . | On the property bar, adjust the Tolerance slider to control the amount of variance allowed from the selected color with higher values creating a larger range of colors. |
3 . | In the document window, do one of the following: |
• | Click to select the color in the middle of the range of colors that you want to use for the selection. |
• | Click and drag over an area to define the range of colors that you want to use for the selection. |
It may take a moment for the selection to be calculated and loaded. |
On the property bar, click the Contiguous button.
On the property bar, click the New Selection button
On the property bar, click the Add To Selection button
On the property bar, click the Subtract From Selection button
The default tolerance for selections is 32. This can be adjusted from 1 to 255.
If you add to the current selection, you add to the range of values that the Magic Wand tool selects rather than create an additional selection with a unique seed color.
You can restrict a selection to a rectangular area by pressing Option + Shift (macOS) or Alt + Shift (Windows), and dragging a bounding rectangle in your image.
You can restore the default settings by clicking the Reset Tool button on the property bar.
Adding to a selection by using the Magic Wand tool
To auto-generate a selection based on image characteristics |
1 . | Choose Select ![]() |
2 . | From the Using list box, choose one of the following options: |
• | Paper — creates a selection by using the current paper texture |
• | Image Luminance — creates a selection based on the light and dark areas of the current image |
• | Current Color — creates a selection of pixels based on the current main color. Before using this option, you can pick a color from the image by using the Dropper tool |
If you want to invert the selection, enable the Invert check box. |
To auto-generate a selection based on clone characteristics |
1 . | Open or create an image. |
2 . | In the Clone Source panel (Window ![]() |
• | To browse for a file, enable the Browse option. |
• | To clone a currently open document, enable the Current Document option, and choose a document from the list box. |
• | To embed the active texture, enable the Current Texture option. |
3 . | Choose Select ![]() |
4 . | From the Using list box, choose one of the following: |
• | 3D Brush Strokes — creates a selection that is based on the difference between the current image and the clone source. If no clone source is selected, the current pattern is used. |
• | Original Luminance — produces a selection in the current document based on the light and dark areas of the clone source. If no clone source is selected, the current pattern is used. |
To auto-generate a color-based selection |
2 . | Click in the document window to pick a color. |
3 . | In the Color Select dialog box, move the Range sliders in the Hue, Saturation, and Value areas. |
These sliders control the selected range of colors. |
4 . | Move the Feather sliders in the Hue, Saturation, and Value areas. |
Feathering helps soften the selection edge. |
5 . | The Preview window shows the selected area as a red overlay on the image. Drag in the Preview window to see other parts of the document. |
