Dropping layers with the canvas
You can drop a layer or layer group to merge its contents with the canvas. Dropping a layer is a permanent change. Once layers are dropped, you can no longer access the layers’ content separately from the canvas. You can drop specific layers or you can drop all layers at once, this also known as flattening an image.
When you drop a layer, you can choose to create a selection based on the layer contents. If the layer has a layer mask, the mask is used to make the selection. For more information, see Creating and deleting layer masks and Selections and transformations.
To drop a layer Back to Top
In the Layers panel, select the layers (or groups) that you want to drop, and do one of the following:
In the Layers panel, click the Layer options button , and choose Drop All.
In the Layers panel, click the Layer options button , and choose Drop and Select.
When the Layer Adjuster tool is selected in the toolbox, you can also drop layers by clicking the Merge flyout button on the property bar, and choosing the command you want.
