Corel Painter Help :
Weaves : Editing and saving weaves
You can edit a sample weave from the Weaves panel to make it your own. For example, you can scale the weave or modify the thickness of the threads.
After altering the scale, thickness, or color of a weave, you can save the changes as a new weave to the Weaves library for future use. For more information, see Working with libraries.
1 . |
Choose Window Media Panels Weaves Control Panel. |
2 . |
Click the Weave selector, and click a weave in the Painter Weaves library panel. |
3 . |
Click the Three-Dimensional Weave button . |
4 . |
Move the Horizontal Scale slider and Vertical Scale slider to the right to increase the scale or to the left to decrease the scale. |
5 . |
Move the Horizontal Thickness slider and Vertical Thickness slider to the right to increase the thickness or to the left to decrease the thickness. |
![*](images/note.svg)
Thickness sliders affect only the three-dimensional display. When you select a two-dimensional display, the thickness sliders have no effect.
1 . |
Choose Window Color Panels Color Sets. |
2 . |
In the Weaves panel (Window Media Panels Weaves Control Panel), click the Weave selector, and click a weave on the Painter Weaves library panel. |
3 . |
Click the Weave Options button , and choose Get Color Set. |
5 . |
Hold down Command (macOS) or Ctrl (Windows), and then click the color swatch that you want to replace on the Color Set Libraries panel. |
6 . |
In the Weaves panel, click the Weave Options button , and choose Put Color Set. |
1 . |
In the Weaves panel (Window Media Panels Weaves Control Panel), click the Weave options button , and choose Save Weave. |
2 . |
In the Save Weave dialog box, type a name for the weave. |
![*](images/tip.svg)
If you want to preserve the default weave, type a new name for the modified weave. If you don’t type a new name, Corel Painter saves the modified weave using the default weave’s name.
The new weave pattern appears in the current Painter Weaves library.
