Corel Painter Help :
Color management : Embedding color profiles when saving files
Embedding a color profile attaches the color profile to the document to ensure that the same colors you used are shared with anyone who views or prints the document. In this way, you help ensure color consistency when files are viewed, modified, or reproduced.
If you did not assign a color profile to the file, the default color profile is embedded.
The following file formats support color profile embedding:
2 . |
In the Save Image As dialog box, use the controls to specify a location and filename. |
3 . |
From the Format list box (macOS) or the Save As Type list box (Windows), choose one of the following file formats: |
![*](images/tip.svg)
If you do not want to embed the color profile, you need to disable the Embed Profile check box.
