• | To erase an image area |
You can erase any part of your image with the Eraser tool or an Eraser brush. Corel Painter lets you fully customize the Eraser tool by using the property bar or the General panel. For example, on the property bar, you can adjust the width of the brushstrokes, control the opacity of erased areas, and select from a great variety of dab profiles. You can link opacity and size to stylus pressure or specify a fixed value. To learn more about the options that you can set on the General panel, see General controls.
You can choose a dab profile for a brushstroke with harder (left) or softer (right) edges.
1 . | In the Layers panel, choose the layer on which you want to erase. |
2 . | Choose the Eraser tool in the toolbox. |
3 . | Perform a task from the following table. |
On the property bar, type a value in the Size box or move the Size slider.
Tip: To link size to an expression, click the Size flyout button , and choose an option from the Expression list box.
On the property bar, type a percentage in the Opacity box or move the Opacity slider.
Tip: To link opacity to an expression, click the Opacity flyout button , and choose an option from the Expression list box.
On the property bar, click a Dab profile button.
You can erase in straight lines by clicking the Straight line strokes button on the property bar, clicking a point on the canvas where you want to start your line, and clicking where you want to end the line.
You can also erase image areas by choosing the Brush tool in the toolbox and choosing Erasers from the Brush Category selector on the Brush Selector bar. For more information about Eraser brushes and a list of sample brushstrokes, see Erasers.
