Corel Painter Help :
Workspace tour : Saving, exporting, and importing custom palettes
You can save a custom palette as a Painter Custom Toolbox (BOX) file so that its custom content such as custom brushes, papers, patterns, and flow maps are saved with the file. You can share the saved custom toolbox (palette) with others or store it for later use.
You can also export a custom palette to the Painter Palette File (PAL) format to make it compatible with earlier versions of Corel Painter. However, any custom content included in the palette is not saved with the file.
1 . |
Choose Window Custom Palette Organizer. |
4 . |
In the New Palette File dialog box, type a name in the File Name text box. |
![*](images/note.svg)
Custom nozzles, scripts, gradients, looks, and weaves are not supported. Buttons for such custom content will not function when the custom toolbox is imported.
Any non-custom items that are already in the application appear as duplicates.
1 . |
4 . |
Custom content is not saved with the file.
1 . |
2 . |
In the Custom Palette Organizer, choose a palette from the Custom Palette list. |
4 . |
In the Open Palette File dialog box, choose the file where the custom palette is saved. |
Only custom palette files created with Corel Painter version 8.1 or later are supported. Custom palettes created with version 7 or earlier cannot be loaded.
