You can use different modes to fill an area of a mosaic with tiles. You can use the Start with triangle mode to fill a wedge-shaped area by applying a brushstroke that starts with a triangular shaped tile.
The Start with triangle mode creates a perfect wedge in the "V."
You can use the Respect edge of image mode to automatically insert a space at the perimeter of the image so that the tiles you insert at the edge of the image do not pass the edge.
The white tiles that surround the image respect the edge, while the black tiles do not.
1 . |
Choose Effects Esoterica Make Mosaic and Tessellation. |
2 . |
In the Options area, enable one or both of the following check boxes: |
