You can use the Freehand method to adjust colors. This method lets you draw a curve to produce dramatic results. It’s particularly useful for creating posterized or solarized effects.
Freehand method of color correction
1 . |
Choose Effects Tonal Control Correct Colors. |
2 . |
In the Color Correction dialog box, choose Freehand from the Method list box. |
Red — allows you to adjust only the red curve |
Green — allows you to adjust only the green curve |
Blue — allows you to adjust only the blue curve |
Master — allows you to adjust all color curves at once |
![*](images/tip.svg)
You can clear all corrections so that you can start again by clicking Reset.
You can compare the adjusted image with the original image by enabling and disabling the Preview check box.
