• | To access the general preferences |
Disables the Scale feature with brush size option in all areas of the application.
Displays the Using Audio Expression dialog box every time you use Audio Expression. Enable this check box if you previously enabled the Do not show this again check box in the Using Audio Expression dialog box.
Displays the Presentation Mode dialog box every time you use Presentation Mode. Enable this check box if you previously enabled the Do not show this again check box in the Presentation Mode dialog box.
Enable this check box if you previously enabled the Commit and don’t ask again check box in the Commit dialog box.
• | Do one of the following: |
• | (macOS) Choose Corel Painter 2020 menu Preferences General. |
• | (Windows) Choose Edit Preferences General. |
