Before printing an image, you can specify printer properties, including paper size and device options. For example, you can specify printer features such as duplexing stapling. The preferences that you choose depend on several factors: the type of output device to be used, whether the printed output will be in color or in black and white, and whether you are printing separations. You can print Corel Painter images on a wide variety of printers, including PostScript, Windows Graphics Device Interface (GDI), and QuickDraw, and high-resolution imagesetters.
You can manually adjust the page size, orientation, and margin settings to match the standard paper settings for printing. You can also print an image that is larger than a selected page size by automatically resizing the image to fit the page. For example, you can automatically resize a 12-by-12-inch image to fit on an 8.5-by-11-inch page.
You can also print an image to a file, so you can send the file to a print service provider for printing. Some of these options are available only on the Windows operating system.
(macOS) Click the Show Details button, and choose an option from the list box (such as Page Attributes, Layout, Color Matching, or Paper Feed). |
(Windows) On the General page, choose a printer from the Select Printer area, enable an option in the Page Range area, and type a value in the Number of copies box. |
(macOS) Click the Show Details button, choose Corel Painter 2020 from the list box, and enable the Print Grayscale check box. |
Choose the Painter 2020 tab, and enable the GDI Printing option.
Choose the Painter 2020 tab, and enable the Color PostScript option.
Choose the Painter 2020 tab, and enable the Separations option.
Choose the Painter 2020 tab, and enable the B & W PostScript option.
(macOS) Choose File Print, click the Show Details button, and choose Page Attributes from the list box. |
3 . |
In the Orientation area, choose one of the following options: |
Portrait — sets the page’s height to be greater than its width |
Landscape — sets the page’s width to be greater than its height |
(macOS) Choose Margins and Layout from the list box, and choose any margins and layout options you want. |
(Windows) In the Margins area, specify values in the Left, Right, Top, and Bottom boxes. |
(macOS) Click the Show Details button, choose Corel Painter 2020 from the list box, and enable the Fit to page check box. |
![*](images/note.svg)
You must enable this option to print images larger than the page size.
2 . |
On the General page, enable the Print to file check box. |
4 . |
In the Save Print Output As dialog box, type a filename in the File name box. |
