• | To scale a selection |
• | To rotate a selection |
1 . | In the toolbox, click the Transform tool |
If the Transform tool is not displayed in the toolbox, click and hold the Layer Adjuster tool |
2 . | On the property bar, click the Scale button |
3 . | Perform a task from the following table. |
Drag a side, top, or bottom handle. On the property bar, click the Commit Transformation button
Drag a corner handle. On the property bar, click the Commit Transformation button
Hold down Shift while you drag a corner handle. On the property bar, click the Commit Transformation button
Hold down Alt + Shift (Windows) or Option + Shift (macOS), and drag a corner handle. On the property bar, click the Commit Transformation button
Hold down Alt (Windows) or Option (macOS), and drag a corner handle. On the property bar, click the Commit Transformation button
Drag a side handle to scale horizontally.
You can also scale a selection by choosing Edit Transform
Scale, and specifying the horizontal and vertical scale percentages in the dialog box.
2 . | On the property bar, click the Rotate button ![]() |
3 . | Move the pointer outside the border of the selection’s bounding box. |
4 . | Drag a corner handle. |
If you want to constrain the rotation by 15-degree increments, hold down Shift while dragging. |
5 . | On the property bar, click the Commit Transformation button |
You can also Rotate a selection by choosing Edit Transform
Rotate, and specifying the rotation angle in degrees in the dialog box. A positive number rotates clockwise; a negative number rotates counterclockwise.
