• | To customize cloning behavior |
1 . | Do one of the following: |
• | (macOS) Choose Corel Painter 2020 menu ![]() ![]() |
• | (Windows) Choose Edit ![]() ![]() |
2 . | Perform a task from the following table. |
Disable the Close source image check box.
Enable the Close source image check box.
Enable the Open Clone Source panel check box.
Enable the Clear Canvas check box.
Enable the Turn on Tracing Paper check box.
Enable the Switch to cloner brushes check box.
Enable the Clone color check box.
To enable the Clone color check box, you must disable the Switch to cloner brushes check box.
Enable the Show Edit Source Image dialog box check box.
Note: The message reminds you that if you choose to create a new clone source or update the currently selected clone source, all layers in the source image will be flattened and all undo levels will be lost.
* Please note that all settings marked with an asterisk apply only to Quick Clone. |
