• | To set preferences for drawing shape outlines |
• | To set preferences for filling shapes |
• | To set preferences for shape tools |
1 . | Choose a shape tool from the toolbox. |
2 . | On the property bar, perform an action from the following table: |
Enable the Stroke check box.
Disable the Stroke check box.
Click the Stroke Color flyout button, and choose a color from the color selector.
Click the Shape Attributes flyout button
Move the Stroke Width slider.
You can also set preferences for drawing shape outlines in the Shape Attributes panel (Window Shape Attributes).
Enable the Fill check box.
Disable the Fill check box.
Click the Fill Color flyout button, and choose a color in the color selector.
You can also set preferences for filling shapes in the Shape Attributes panel (Window Shape Attributes).
You can also adjust shape flatness by adjusting the Flatness slider.
1 . | Do one of the following: |
• | (macOS) Choose Corel Painter 2020 menu ![]() ![]() |
• | (Windows) Choose Edit ![]() ![]() |
2 . | Perform a task from the following table. |
In the Drawing Options area, enable the Big Handles check box. This can make them easier to grab and drag. If you want big points, enable this option.
In the Colors area, click Wing/Bezier Handle, and choose a color.
In the Colors area, click Selected Point/Anchor, and choose a color. The unselected anchor points appear "hollow."
