Using channels and layer masks to create texture
Corel Painter lets you produce surface texture based on an alpha channel or a layer mask. You can use this method only if you added an alpha channel, or a layer that contains a layer mask, to the image.
When you apply the texture to a channel, the area that surrounds the edges of the channel appears raised. When you apply texture to a layer mask, the layer mask acts as a boundary for the texture and the texture appears around the edges. For more information, see Creating and deleting layer masks.
alpha channel texture
Before (left) and after (right) adding texture based on a saved alpha channel
Before (left) and after (right) adding texture based on a layer mask
To create surface texture based on a channel or layer mask Back to Top
