Corel Painter Help :
Painting : Applying freehand and straight brushstrokes
You can draw unconstrained lines by using the freehand drawing style, or you can draw straight lines.
When you draw a freehand stroke, you can drag with any motion or in any direction. The stroke follows your path.
Dragging to create freehand strokes.
When you draw a straight line stroke, Corel Painter connects points with a straight line.
To create a straight line stroke, you click to add the first point and then click or drag to create the stroke.
![*](images/tip.gif)
You can use shortcut keys to toggle between the freehand and straight line drawing styles. Press B to choose the freehand style, or V to choose the straight-line style.
Press Return (Mac OS) or Enter (Windows) to close the polygon. The final point is connected to the origin with a straight line. |
Click the Freehand Strokes button to return to the freehand drawing style without closing the polygon. |
6
Press V to end the current polygon without closing it, so that you can begin a new one. |
You can also paint in a straight line by holding down Shift as you drag on the canvas.
