• | To adjust bristle controls |
• | To scale bristles with the brush size |
The Bristle controls allow you to adjust the appearance of bristle brushes, such as Camel Hair, Flat, Palette Knife, and Bristle Spray. You can specify the number of bristles, or bristle density (Feature). You can also control how far the bristles spray out, or fan out, when applying brushstrokes (Spread). This control is linked to the Tilt expression. For example, the more you tilt the stylus, the greater the bristles will fan out.
1 | Choose Window ![]() ![]() |
2 | Perform an action from the following table: |
Move the Feature slider. The higher the setting, the denser the brush bristles.
Move the Spread slider. This control is linked to the Tilt expression.
2 | Enable the Scale Feature with Brush Size check box. |
You can also scale a brushstroke’s features with the brush size by clicking the Scale Feature with Brush Size button on the Brush property bar.
You can also disable the scaling option in all areas by choosing Corel Painter 2016 menu Preferences
General (Mac OS) or Edit
Preferences
General (Windows), and enable the Disable feature scaling when resizing brush.
