| • | To create a flow map from a paper texture |
| • | To capture a flow map from an image |
| • | To customize a flow map |
To customize an existing flow map, you can rotate it. You can also modify the scale, contrast, and several other settings of a flow map the same way that you would modify paper texture. For more information, see Working with paper texture and grain. Note that flow maps benefit from increased scale and contrast; therefore, if you create a flow map from a paper texture or image, you should increase the scale and contrast.
An area of an image was selected (1) to create a flow map (2).
| 1 | Choose Window |
| 2 | Click a paper texture swatch. |
| 3 | Choose Window |
| 4 | In the Flow Maps panel, click the Flow Maps options button |
| If you want to rename the flow map, right-click the swatch in the Flow Map Libraries panel, and choose Rename Flow Map. |
| 1 | Open or create an image. |
| 2 | Choose the Rectangular Selection tool |
| 3 | Drag in the document window to select the area of the image. |
| If you want to blend the distinction between tile borders, drag the Crossfade slider to the right in the Capture Flow Map dialog box. |
| 5 | Type a name in the Save As text box. |
| The flow map is added to the currently selected library. |
You can also capture a flow map from the Flow Map Libraries panel by clicking the Capture Flow Map button
| 1 | Choose Window |
| 2 | In the Flow Maps panel, perform one or more actions from the following table. |
Move the Flow Map Rotation slider.
Click the Invert Toggle button
Move the Flow Map Scale slider
Move the Flow Map Contrast slider
Move the Flow Map Brightness slider
