• | To choose a brush tip profile |
The Dab Profile panel displays a selection of dab profiles that you can apply to your brushes. Each brush tip profile shows a cross-section of density distribution across the diameter of the dab. You can think of a brush tip profile as a bell-curve graph representing the density spread across the brush dab.
Each Corel Painter brush uses one of the following brush tip profiles.
Artists’ Oils brush tip profiles
There are six brush tips designed specifically for Artists’ Oils brushes. You can also use any brush tip, listed in the table above, with Artists’ Oils brushes.
Designed for Artists’ Oils palette knives, it provides maximum density throughout, with rapid falloff at the edge.
Designed for Artists’ Oils palette knives, its maximum density is off-center, with uneven falloff.
Designed for Artists’ Oils palette knives, it provides maximum density at one edge, with consistent falloff to the other edge.
There are six tip profiles designed specifically for the Hard Media variants.
1 | Choose Window ![]() ![]() |
2 | In the Dab Profile panel, click a brush tip profile icon. |
