| • | To select shapes |
You need to select a shape before moving or modifying it. When a shape is selected, you can see the shape’s outline path and anchor points. You can also select a shape layer to modify it. For more information, see Selecting layers.
| To select shapes |
Choose the Shape Selection tool
Hold down Shift, and click the shapes with the Shape Selection tool
If you are using the Layer Adjuster tool, you can switch to the Shape Selection tool
by double-clicking a shape.
