• | To set stroke jitter |
The Stroke Jitter controls introduces a randomized jitter to the brushstroke. Instead of appearing directly along the stroke, dabs appear randomly outside the brushstroke path. You can also set an Expression setting to further control the Stroke Jitter effect. For more information, see Expression settings.
Brushstrokes with Stroke Jitter set to 0 (top) and 3.13 (bottom)
Audio Expression lets you link the Stroke Jitter effect to audio input from your microphone, or internal audio such as streaming music. The jitter changes in synch with the audio signal.
Varying Stroke Jitter in synch with audio
You can also find feature-specific jitter controls on the following brush control panels: Opacity, Grain, Size, Angle, Airbrush, Impasto, and Color Expression.
1 | Choose Window Brush Control Panels Stroke Jitter. |
2 | Move the Stroke Jitter slider to the left to decrease deviation from the stroke path, or to the right to increase the deviation. |
Adjust the angle of the Direction expression
Move the Direction slider until the desired angle is achieved.
Reverse the effect of an Expression setting
Click the Invert button .
Click the Audio Expression button .
To choose an audio input and adjust audio settings, choose Window Audio Audio Settings Panel. For more information, see Audio Expression.
