• | To add text to an image |
You can add text to an image by using the Text tool . The text that you add is then stored in a text layer, which is automatically created for you as soon as you place the text cursor on the canvas. Each text layer holds a single text block. The text layer is visible in the Layers panel, and is represented by a T icon .
The text layer lets you work with your image without changing any text attributes. However, you can select the text layer and edit it at any time. The text remains fully editable until you drop it onto the canvas. For more information, see Dropping text.
1 | Choose the Text tool from the toolbox. |
2 | Click anywhere in the document window, and type. |
You can also format text by choosing options from the property bar.
You can also format text by choosing Window Text, and choosing options from the Text panel.
