Applying recently used effects
At the top of the Effects menu, Corel Painter displays the last two effects you applied. This lets you quickly reapply frequently used effects. You can also use keyboard shortcuts to apply the last two effects.
To reapply a recently used effect Back to Top
You can also apply a shortcut key to the 2nd Last Effect command by clicking Edit Preferences Customize Keys. Clicking the Effects category in the Application Commands list, clicking the 2nd Last Effect command to select it, and typing a shortcut key in the Shortcut column.
