• | To assign commands to keys |
• | To revert keyboard shortcuts |
• | To manage key sets (Mac OS) |
• | To manage key sets (Windows) |
1 | Do one of the following: |
• | (Mac OS) Choose Corel Painter 2015 menu Preferences Customize Keys. |
• | (Windows) Choose Edit Preferences Customize Keys. |
If you want to modify keyboard shortcuts that you previously stored in a key set, choose the key set from the Key Set list box. |
2 | Choose one of the following options from the Shortcuts list box: |
• | Application Menus — lets you create or modify menu bar command shortcuts |
• | Panel Menus — lets you create or modify panel menu command shortcuts |
• | Tools — lets you create or modify tools shortcuts |
• | Other — lets you create or modify command shortcuts for items that are not menus, panels, or tools |
3 | Choose a command from the Application Commands list. |
4 | In the Shortcut column next to the command, type the shortcut keys you want to assign. |
If you typed a unique shortcut key, you can click OK to exit the Preferences dialog box. |
If the shortcut you assigned is already in use, a message appears below the Application Commands list. To proceed, you need to perform a task from the following table: |
Click Accept.
Click Accept and Go To Conflict.
Click Undo.
Revert to all keyboard shortcuts you created or modified since you opened the Preferences dialog box
Click Reset. In the warning dialog box, click Yes.
Click Defaults. In the warning dialog box, click Yes.
Click Open. In the Open Key Set dialog box, select a key set, and click Open.
Click New. In the Save New Key Set dialog box, type a name for the key set in the Save As box, and click Save.
Click Save. In the Save Key Set dialog box, type a name for the key set in the Save As box, and click Save.
Click Export to HTML. In the Save Summary dialog box, type a name in the Save As box, and click Save.
Click Delete.
Click the Open button . In the Open Key Set dialog box, select a key set, and click Open.
Click the New From Existing button . In the Save New Key Set dialog box, type a name for the key set in the Filename box, and click Save.
Click the Save Active Set button . In the Save Key Set dialog box, type a name for the key set in the Filename box, and click Save.
Click the Create HTML Summary button . In the Save Summary dialog box, type a name in the Filename box, and click Save.
Click the Delete button .
