Exporting movies as QuickTime
You can export a movie as a QuickTime movie on the Windows platform.
QuickTime supports several compression schemes. The following descriptions should help you choose one; however, you’ll probably want to experiment with different compressors and settings to identify the best settings for your work. You may also have additional compression methods available.
The compression ratio is inversely proportional to image quality. The Quality slider allows you to set an optimum level between the amount of compression and image quality. For most work in Corel Painter, it is best to set the Quality slider to High.
You can specify the number of frames you want displayed per second and, with some compression methods, the frequency of key frames. Key frames are used in temporal compression methods. Each key frame is stored in its entirety. The next set of frames, up to the next key, are saved only as changes.
With some compression methods, you can also limit the speed of data transmission with the Limit Data Rate option. The data rate limit overrides the Quality setting, if necessary, to keep the compressed movie within the set limit.
To export a Corel Painter movie as a QuickTime movie Back to Top
