• | To fade an effect |
You use the Fade control to undo a percentage of the last effect applied to the image. You can use this feature to control the intensity of an effect.
Fade was applied to the image (right) to undo a percentage of the last effect (left).
To fade an effect |
1 | Choose Edit Fade. |
To apply Fade, you must have previously applied an effect to the image. |
2 | In the Fade dialog box, move the slider. |
If you change your mind, choose Edit Undo. |
