Applying the Glass Distortion dynamic plug-in
The Glass Distortion dynamic plug-in creates a layer that simulates the appearance of viewing the image through textured glass. You can move the layer in the document to view the distortion over different parts of an image.
glass distortion plug in
A section of an image with Glass Distortion applied.
To create a Glass Distortion dynamic layer Back to Top
Enable the Inverted check box.
Enable the Preview check box.
Click the Reset button.
You can also use the Opacity slider in the Layers panel to adjust the effect.
You can drag the Glass Distortion layer or selection in the document window to distort other areas of the image.
The Glass Distortion dynamic layer using Paper (left) and Image Luminance (right) displacement sources.
