Mouse controls
In theory, a mouse has no pressure information. A mouse button is either on (button down), or off (button up). However, the Corel Painter Mouse controls let you simulate the following stylus settings:
For more information, see Using a stylus vs. a mouse.
You can record and save brushstrokes created with a stylus and then have Corel Painter use the saved settings for the stroke when you switch to a mouse. For more information about using saved brushstrokes to further enhance mouse functionality, see Recording and playing back brushstrokes.
To set pressure for the mouse Back to Top
To set tilt for the mouse Back to Top
To set bearing for the mouse Back to Top
To set rotation for the mouse Back to Top
Rotation is supported only when you are using a brush with the Expression setting set to Rotation. For more information, see Expression settings.
To set ink flow for the mouse Back to Top
