Using selections and transformations when sampling
You can use a selection when sampling an image area in two ways: by making brushstrokes in the destination image obey the selection in the sample source image, or by copying the active selection in the sample source region. These two options can be used individually or together.
These selection options require a Cloning method. They do not work for brushes of other methods that use the Clone Color button on the Color panel.
obey source selection
Use Obey Source Selection to paint in the area that corresponds to the source selection.
copy source selection
Use Copy Source Selection to sample both the selection and the color.
To sample an area of an image by using a source selection Back to Top
This image uses Rotate & Scale sampling with both Obey Source Selection and Copy Source Selection enabled.
