Applying the Serigraphy effect
With the Serigraphy effect, you can use photographs to generate images that appear silk-screened or look like woodblock cuts. When applying the effect, Corel Painter saves each color reduction as a separate layer, so you can edit each layer individually.
Serigraphy
Before (left) and after (right) applying the Serigraphy effect.
To apply Serigraphy effects Back to Top
You can also specify Match and Fill colors by clicking a color in the image.
