• | To set brush size |
• | To set stroke transition |
• | To switch the brush size preview mode |
The Size brush controls determine how Corel Painter varies the width of the brushstroke.
Size lets you control the width of the brush and the brushstroke. As size changes, you may need to adjust the spacing controls for brushes that use nonrendered or dab-based dab types to prevent gaps from appearing in the stroke.
Size controls the width of the brush.
You can choose an Expression setting to create a brush that responds to subtle hand movements. For more information, see Expression settings. You can also adjust the Min setting to specify the range of variability that you want the expression to apply. The Min Size setting represents a percentage of the Size setting and it must be linked to an expression to have an effect. For example, if you choose the Pressure expression on the Size panel, set the Size slider to 40 and set the Min Size slider to 50%, the stroke sizes will vary from 20% to 40% every time you apply pressure. The Min Size control allows you to create a brushstroke that is amazingly realistic. As stylus pressure eases, brushstrokes taper. As pressure increases, brushstrokes widen, just as they would with a real brush.
The minimum and maximum sizes of a stroke can be linked to Expression settings, such as pressure or velocity. The small black circle shows the minimum stroke size, and the gray circle shows the maximum stroke size.
The Size Jitter control lets you introduce more variation to the size of the brushstroke, which enhances the responsiveness and natural appearance of the brushstrokes. You can also use the Smoothness slider to smooth the size variation for a more organic look.
Oils Real Round brushstrokes without Size Jitter (left) and with Size Jitter (right)
Size Step controls the transition between narrow and wide sections of a stroke.
Brushstrokes with Size Step set to 1% (top) and 100% (bottom)
To set brush size |
1 | Choose Window Brush Control Panels Size. |
2 | Move the Size slider to the right to make the brush larger, which makes the transition appear more abrupt. Move the slider to the left to make the brush smaller, which produces a smoother transition. |
Move the Size Jitter slider.
Move the Smoothness slider.
Choose an option from the Expression list box.
Move the Min Size slider.
Adjust the angle of the Direction expression
Move the Direction slider.
You can also set the brush size dynamically onscreen. For more information, see To set brush attributes onscreen.
When adjusting Size Jitter, make sure the Min Size slider is not set to 100%. Setting the Min Size to 100% stops Size Jitter from occurring.
You can also change the brush size from the property bar by adjusting the Size slider or typing a value in the Size box.
2 | Move the Size Step slider to the right to increase the transition between brush sizes. Move it to the left to make the transitions smaller. |
1 | Choose Window Brush Control Panels Dab Preview. |
2 | Click the Preview Size and Shape button . |
