Storing layers as images in the Image Portfolio
The Image Portfolio is a convenient place to store layers as images so you can use them again.
You can create your own Image Portfolio libraries to organize images by category. When you’re creating a library, keep in mind that the smaller the library, the easier it will be to see its contents at a glance.
You can also move items between Image Portfolio libraries. For more information, see Working with libraries.
To display the Image Portfolio panel Back to Top
To add a layer to the Image Portfolio Back to Top
The Image Portfolio holds only pixel-based layers. If you want to add a shape, Watercolor, Liquid Ink, or dynamic layer to the Image Portfolio, you must first convert it to a default layer. In the Layers panel, click the Layer options button panel options, and choose Convert To Default Layer.
To use an image from the Image Portfolio Back to Top
image portfolio
Corel Painter places the Image Portfolio item on a new layer.
