The Divine Proportion tool lets you use guides based on a classical composition method of the same name. When planning your artwork, you can use the guides to create a sense of proportion, which helps maintain interest as the eye of the viewer travels across a drawing or painting.
The Divine Proportion tool can help you establish focal areas.
The Divine Proportion panel lets you change the orientation, size, angle, color, and opacity of the Divine Proportion guide that appears on the canvas. You can also adjust the number of levels to determine how many times a section divides within itself, creating a spiral. You can adjust these settings while you work, and you can save them as a preset. You can also move the Divine Proportion guide to a new position.
To show or hide the Divine Proportion guide |
• | Choose Canvas Compositions, and then choose either Show Divine Proportion or Hide Divine Proportion. |
You can also show or hide the Divine Proportion guide by clicking the Divine Proportion tool in the toolbox and clicking the Enable Divine Proportion button on the property bar.
To set Divine Proportion options |
1 | Choose Window Composition Panels Divine Proportion. |
The Divine Proportion panel appears. |
2 | In the Divine Proportion panel, enable the Enable Divine Proportion check box, and perform a task from the following table. |
In the Orientation area, click one of the Landscape or Portrait buttons.
Move the Size slider to the right to increase the size. Move the slider to the left to decrease the size.
Type a value in the Rotate box to set the degree of the angle.
In the Display area, click the Grid, Spiral, or Axis color picker, and choose a color.
Move the Opacity slider to the left to increase transparency. Move the slider to the right to increase opacity.
Move the Levels slider to the right to increase the number of levels. Move the slider to the left to decrease the number of levels.
You can also set some Divine Proportion options by clicking the Divine Proportion tool in the toolbox and modifying the settings that you want on the property bar.
To save Divine Proportion settings as a preset |
1 | In the Divine Proportion panel, modify the settings you want, and click the Add Preset button . |
2 | In the Add Preset dialog box, type a name for your preset in the Preset Name box. |
3 | Click Save. |
The preset appears in the Type list box. |
You can also save a preset by clicking the Divine Proportion tool in the toolbox and clicking the Add Preset button on the property bar.
To delete a Divine Proportion preset |
1 | In the Divine Proportion panel, choose the preset you want to delete from the Type list box. |
2 | Click the Delete Preset button . |
You can also delete a preset by clicking the Divine Proportion tool in the toolbox, selecting a preset from the Presets list box on the property bar, and clicking the Delete Preset button .
To choose a Divine Proportion preset |
• | In the Divine Proportion panel, choose a preset from the Type list box. |
To move the Divine Proportion guide |
1 | In the toolbox, click the Divine Proportion tool . |
The cursor changes to a hand icon . |
2 | Drag the Divine Proportion guide to a new position. |
