• | To access the Edit Weave dialog box |
You can draft a weave using the Edit Weave dialog box, which is intended for an 8-harness, 8-treadle loom.
Edit Weave dialog box: the numbers above correspond to the numbers in the following table, which describes the main components of the dialog box.
1. Warp
The values in the Warp area specify the threading sequence of the vertical threads in the weave.
2. Warp Colors
The values that appear in the Warp Colors area control the color and number of vertical threads in the weave.
3. Weft
The values in the Weft area specify the treadling sequence of the horizontal threads in the weave.
4. Weft Colors
The values that appear in the Weft Colors area control the color and number of horizontal threads in the weave.
5. Tromp as Writ
The Tromp as Writ button allows you to copy the warp values and apply them to the weft threads.
6. Tieup
The Tieup area allows you to control the interlacing of the threads by determining which warp rows to use when weaving a weft thread.
1 | Choose Window Media Control Panels Weaves. |
2 | In the Weaves panel, click the Weave options button , and choose Edit Weave. |
