Corel Painter Help :
Layers : Copying layer masks
You can copy a layer mask to an alpha channel or copy a channel to a layer mask. The name of a layer mask in the Channels panel reflects the name of the layer ([Layer Name] [Layer Mask]). Although you cannot change the name of a layer mask, it automatically updates if you change the layer name.
2 . |
In the Channels panel, click the Channel options button , and choose Duplicate. |
3 . |
In the Duplicate Channel dialog box, enable the New Alpha Channel option. |
![*](images/tip.svg)
You can also copy a channel to an existing channel, so that the existing channel is replaced. To do this, enable the Replace Existing Alpha Channel option, and choose the existing channel from the list box.
3 . |
In the Channels panel, select the channel you want to copy. |
5 . |
In the Duplicate Channel dialog box, enable the Replace Existing Alpha Channel option. |
