Custom palettes behave like the standard panels. For more information about working with panels, see Rearranging panels and palettes.
To quickly create a custom palette |
• | Press Shift, and do any of the following: |
• | Drag a brush variant from the Brush Selector panel (Window ![]() |
• | Drag a paper, flow map, or media library thumbnail from the Paper Libraries (Window ![]() ![]() ![]() ![]() ![]() ![]() |
To add menu commands, controls, or tools to a custom palette |
1 . | Choose Window ![]() ![]() |
2 . | From the Select Custom Palette list box, choose New to create a new palette or select an existing custom palette. |
3 . | With the Create Palette/Add Command dialog box open, perform a task from the following table: |
Choose a menu item from the Other menu.
Choose a menu item from the Panel Menus menu.
Choose a menu item from the Tools menu.
4 . | In the Create Palette/Add Command dialog box, click Add, and then click OK. |
To rearrange controls on a custom palette |
• | Hold down Shift and drag a control on a custom palette to a new position. |
To open or close a custom palette |
• | Perform a task from the following table. |
To change the appearance of items on a custom palette |
1 . | Do one of the following: |
• | (macOS) Holding down Control, click an item. |
• | (Windows) Right-click an item. |
2 . | Perform a task from the following table. |
Choose Set Custom Icon, and locate the image you want.
Choose Text View.
Choose Icon View or Wide Icon View.
To change the size of the icons, click the Options button in the custom palette, and choose Small Icons or Large Icons.
