Cutting and joining shape segments
You may want to open a shape so that you can add new curves or connect to another open shape. You can do this with the Scissors tool. You can also connect any two endpoints — of the same shape or of different shapes. This lets you close an open shape or attach one shape to another.
To cut a shape Back to Top
The Scissors tool opens and closes to cut the path.
After a path is cut, it can be moved.
To join endpoints Back to Top
Use the Shape Selection tool to select two endpoints.
Use the Join Endpoints command to connect two endpoints.
