Filling an area with a sampled image
You can apply a transformed sample by filling, instead of using a brush. Filling allows you to cover a large area evenly, without much effort. Filling is supported only when you use perspective or bilinear sampling, with or without tiling.
To apply a transformed sample as a fill, you need to set both sample source and destination reference points, as you would when applying a sample with a brush. For information, see Applying transformations when sampling.
If you want to save the sample source reference area as a pattern for future use, you can capture the pattern. For more information, see Creating and editing patterns.
To fill with a transformed source image Back to Top
The destination points determine where the transformation occurs.
You can use transformed clone information to make a brick pattern become a steep wall.
