Corel Painter Help :
Layers : Storing layers as images in the Image Portfolio
The Image Portfolio is a convenient place to store layers as images so you can use them again.
You can create your own Image Portfolio libraries to organize images by category. When you’re creating a library, keep in mind that the smaller the library, the easier it will be to see its contents at a glance.
You can also move items between Image Portfolio libraries. For more information, see Working with libraries.
Choose Window Media Library Panels Images. |
If the Image Portfolio panel is not expanded, double-click the Image Portfolio panel tab. |
3 . |
In the Image Portfolio panel, click the Image Portfolio options button , and choose Add Image To Portfolio. |
4 . |
In the Save Image dialog box, type a name in the Save As box. |
The Image Portfolio holds only pixel-based layers. If you want to add a shape, Watercolor, Liquid Ink, or dynamic layer to the Image Portfolio, you must first convert it to a default layer. In the Layers panel, click the Layer options button
, and choose Convert To Default Layer.
1 . |
Corel Painter places the Image Portfolio item on a new layer.
