Corel Painter lets you produce surface texture based on an alpha channel or a layer mask. You can use this method only if you added an alpha channel, or a layer that contains a layer mask, to the image.
When you apply the texture to a channel, the area that surrounds the edges of the channel appears raised. When you apply texture to a layer mask, the layer mask acts as a boundary for the texture and the texture appears around the edges. For more information, see Creating and deleting layer masks.
Before (left) and after (right) adding texture based on a saved alpha channel
Before (left) and after (right) adding texture based on a layer mask
1 . |
In the Layers panel, select a layer or the canvas. |
2 . |
Choose Effects Surface Control Apply Surface Texture. |
