| • | To adjust the Airbrush feature spacing |
| • | To set paint spread |
| • | To set ink flow |
The Airbrush controls allow you to adjust the amount and the displacement of the media that is applied by an airbrush.
Feature lets you set the spacing in between individual paint droplets.
Flow controls how much media is applied by an airbrush stroke. The Flow control acts like the needle control on a real airbrush. Because the airbrush dab types deposit many small dabs to create their spray-paint look, you might need to cut down on the flow to speed up the airbrush.
You can also link an Expression setting to both the Flow and Feature controls. This lets you link the controls to a stylus or mouse movement. You can choose different Expression settings for each. For example, you can link Flow to the Pressure expression and link Feature to the Tilt expression.
You can also adjust the Min setting to specify the range of variability that you want the expression to apply. The Min Flow and Min Feature settings represent a percentage of the Flow and Feature settings and they must be linked to an expression to have an effect. For example, if you link the Pressure expression to the Flow control, set the Flow slider to 40% and set the Min Flow slider to 50%, the amount of flow will vary from 20% to 40% every time you apply pressure with the stylus.
Spread controls how paint spreads out as it is applied. In other words, it sets the size of the cone of spread from the tip of the airbrush or spray can. A good range for the Spread setting is 30% to 40%. Narrow settings for Spread and Angle can cause problems. Narrow settings for Spread and Tilt can cause paint to be deposited away from the cursor.
Flow Jitter and Feature Jitter let you adjust the amount of variation that you want these controls to apply when using the airbrush, which produces more realistic results.
Broad Wheel Airbrush brushstrokes without Flow Jitter (left) and with Flow Jitter (right)
Finer Spray Airbrush brushstrokes without Feature Jitter (left) and with Feature Jitter (right)
| 1 | Choose Window |
| 2 | Move the Feature slider to adjust the paint droplet spacing. The higher the setting, the farther apart the paint droplets will appear. |
Move the Feature Jitter slider.
Choose an option from the Expression list box.
Move the Min Feature slider.
Adjust the angle of the Direction expression
Move the Direction slider.
When adjusting Feature Jitter, make sure the Min Feature slider is not set to 100%. Setting the Min Feature to 100% stops Feature Jitter from occurring.
| 1 | Choose Window |
| 2 | Move the Spread slider to the left to reduce the amount of spread, or to the right to increase the amount of spread. |
| To set ink flow |
| 1 | Choose Window |
| 2 | Move the Flow slider to the left to reduce the smallest amount of media applied with a stroke, or to the right to increase it. |
Move the Flow Jitter slider.
Move the Min Flow slider.
When adjusting Flow Jitter, make sure the Min Flow slider is not set to 100%. Setting the Min Flow to 100% stops Flow Jitter from occurring.
