| • | To apply a pattern as a fill |
| • | To adjust the appearance of a pattern |
Left: A pattern scaled at 20%. Right: The same pattern scaled at 100%.
| 1 | Choose Window |
| 2 | Click the Pattern selector, and click a pattern in the Pattern library panel. |
| 3 | To apply a pattern to: |
| • | The canvas — Click the Canvas in the Layers panel. |
| • | A selection — Click a selection tool from the toolbox, and drag in the document window to select an area. |
| • | A layer — Click a layer in the Layers panel. |
| 4 | Choose the Paint Bucket tool |
| 5 | In the document window, click the canvas, selection, or layer. |
On the property bar, type a value in the Tolerance box or adjust the slider.
On the property bar, type a value in the Feather box or adjust the slider.
On the property bar, click the Anti‑Alias button
Anti-aliasing is desirable when the Feather setting is set to zero or extremely low.
The image must be larger than the tile in order for the tiling to be visible in an image.
You can also choose a pattern from the Pattern Selector in the toolbox or by choosing Edit
Fill.
| 1 | Choose Window |
| 3 | Enable one of the following options: |
| • | Rectangular Pattern Type |
| • | Horizontal Pattern Type |
| • | Vertical Pattern Type |
| If applicable, adjust the Pattern Offset slider |
| 4 | Adjust the Pattern Scale slider |
| After you set these options, the pattern is ready to use. |
