| • | To create a brush dab shape |
This musical note was captured as a brush dab.
| 1 | On a white background, draw a shape in black. |
| Use shades of gray to define the transparent areas of the dab. |
| To follow stroke direction, a captured brush set must face toward the right side. |
| 2 | Choose the Rectangular Selection tool |
| 3 | Drag across your brush shape to create a square selection. |
| Corel Painter uses the selected area to set the brush size. When the brush is created, the selected area is sampled to compute each brush dab. |
| 4 | Click the Brush Selector on the Brush Selector bar. |
| 5 | In the Brush library panel, choose the brush category in which you want to save the variant for the captured dab shape. |
| 6 | Click Brush library options button |
| 7 | If necessary, choose Window |
| 8 | Draw with the brush on the canvas. |
| If you like the results you’ve captured, you can save the brush as a new variant. For information about how to save customized brushes for later use, see Saving and deleting brush variants. |
You can paint with a captured brush just as you would with other brushes.
