| • | To create a tessellation |
| • | To create a tessellation from a clone source |
| • | To color tessellations |
You can create a tessellation from a clone source.
A finished tessellation resembles stained glass.
You can base your Tessellation on Triangles, Cracks or Pieces.
You can also add points to a specified area to create a different effect.
Adding points in the shape of a letter. The letters appear as a swath of smaller polygons.
| 1 | Choose Effects |
| 2 | Choose Dimensions from the Settings list box. |
| 3 | Adjust the Grout slider to set the grout line thickness. |
| 4 | Click the grout color button and select a color. |
| 5 | Click Done. |
| 6 | Choose Effects |
| 7 | Choose one of the following tile shapes from the Display list box. |
| • | Triangles |
| • | Cracks |
| • | Pieces |
| 8 | Choose one of the following from the Options list box: |
| • | 500 Random Points — generates a tessellation by using random points |
| • | 500 Evenly-Spaced Points — generates a tessellation by using evenly-spaced points |
| Corel Painter forms polygons by connecting the points according to the display type. |
With the Make Tessellation dialog box open, click or drag in the tessellation where you want to add more intensity.
Choose Reset from the Options list box.
You can add additional points by repeating the command 500 Random Points or 500 Evenly-Spaced Points from the Options list box.
You can also add points by alternating between dragging and using an add-points commands. The points accumulate and the total number of points appears in the lower corner of the Make Tessellation dialog box.
| 1 | Choose File |
| 2 | Choose File |
| 3 | Click the Clone Color button |
| 4 | Choose Effects |
| 5 | Choose one of the following tile shapes from the Display list box. |
| • | Triangles |
| • | Cracks |
| • | Pieces |
| 6 | From the Options list box, choose one of the following: |
| • | 500 Clone-Spaced Points — generates a tessellation by using a clone source. Darker image areas produce a greater density of points. |
| • | 500 Inverse Clone-Spaced Points — generates a tessellation by using a clone source. Lighter image areas produce a greater density of points. |
You can also adjust the grout spacing by choosing Effects
Esoterica
Make Mosaic, and adjusting the Grout slider.
| 1 | In the Make Mosaic dialog box, select the Change Tile Color tool |
| 2 | From the list box below the Change Tile Color tool, choose Color. |
| 3 | In the Colors panel, choose a bright main color. |
| 4 | Drag to create a stroke in the document, or click individual tiles. |
| Colored, tessellated tiles appear beneath your stroke. |
You can also base the color on the color in a clone source if you enable Clone Color in the Colors panel.
