| • | To assign commands to keys |
| • | To revert keyboard shortcuts |
| • | To manage key sets |
| 1 | Do one of the following: |
| • | (Mac OS) Choose Corel Painter X3 |
| • | (Windows) Choose Edit |
| If you want to modify keyboard shortcuts that you previously stored in a key set, choose the key set from the Key Set list box. |
| 2 | Choose one of the following options from the Shortcuts list box: |
| • | Application Menus — lets you create or modify menu bar command shortcuts |
| • | Panel Menus — lets you create or modify panel menu command shortcuts |
| • | Tools — lets you create or modify tools shortcuts |
| • | Other — lets you create or modify command shortcuts for items that are not menus, panels, or tools |
| 3 | Choose a command from the Application Commands list. |
| 4 | In the Shortcut column next to the command, type the shortcut keys you want to assign. |
| If you typed a unique shortcut key, you can click Ok to exit the Preferences dialog box. |
| If the shortcut you assigned is already in use, a message appears below the Application Commands list. To proceed, you need to perform a task from the following table: |
Click Accept.
Click Accept and Go To Conflict.
Click Undo.
Revert to all keyboard shortcuts you created or modified since you opened the Preferences dialog box
Click Reset. In the warning dialog box, click Yes.
Click Defaults. In the warning dialog box, click Yes.
Click the Open button
Click the New From Existing button
Click the Save Active Set button
Click the Create HTML Summary button
Click the Delete button
